Discuss rcd tripping on a ring main in the Electrical Forum area at ElectriciansForums.net
his hair .LoL.As above what other tests have you carried out
With no Ns connected wont you have an imbalance in the circuit?ok so got continuity not shorts insulation resistance low but not too low at 16meg and again all I have connected or two lives of the ring no neutrals for any circuit no earths for any circuit. RCD stays on until I turn the breaker on. Never come across a fault like it
For some reason the OP seems to be saying no Ns connected.If this is a dual rcd board and I know this is obvious but are the neutrals definitely in the correct neutral bar.
I'm a bit confused myself on this one. Don't understand the situation.For some reason the OP seems to be saying no Ns connected.
Reply to rcd tripping on a ring main in the Electrical Forum area at ElectriciansForums.net
