R
rs6mra
Hi Guys,
I need to replace my halogen security light fitting with one that is LED and also comes with PIR.
As this is a swap, am i allowed to do this myself based on current regulations?
If so can you recommend a good security light fitting with PIR? I have looked at a few online and went on the read the reviews whereby the issue surrounding some without dusk and dawn functions were highlighted.
Thanks.
Welcome to the forum rs6mra, I've approved you for general forum, when admin' is next online you will be given DIY access and the thread relocated, this won't affect any existing posts made. :)
Hi Guys,
Thanks.
easy enough job for DIY. recommend fitting by Diamond LED. a 30watt LED is close to 300watt halogen for comparison. you need some way of proving that the fitting has a good earth.
Thanks for your reply. Just to be clear, do you mean a good quality unit that is earthed? If so any links would be most appreciated.
Thanks once again. Is the test equipment a DIY option worth considering or is it now becoming a case of getting someone in?
Replacing security light fitting
DIY Electrical Advice
rs6mra,
rs6mra,
