- Dec 18, 2011
- 5,379
- 6,732
- 405,788
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Hi,
Around 4 years ago I had an electric shower fitted by a 'jack of all trades' chap before I new anything about Part P. He basically left the cable along the floor, up against the skirting. I popped some trunking on it just to make it look a bit more tidy and protect it. The cable runs from the shower to DP switch outside of the downstairs shower room and then down from the switch to the floor (embedded in wall), along the floor (in trunking in the hallway) and then up vertically to the CU.
I want to run the cable behind the skirting, so my question is : Do I need to enclose the cable in earthed metal conduit or can I use normal plastic capping?
If it was plastered I wouldn't be questioning it, it would have to be protected as it is outside of the permitted route and less than 50mm from any surface, but it wouldn't be plastered in as its got the skirting covering it.
Thanks.
Thanks.
