hi im currently looking in to smart lights for my alexa to control. My flat is about 6 years old and my current swich is a double that has two browns and two blues going in to separate bits of the switch with 2 earth wires connected at the back of the box. Can anyone tell me if the blues will be neutrals or is there a chance they are switched lives? Thanks
There’s plenty of smart bulbs available that work with Alexa. Most do require a hub of some kind for example Hive, but you don’t need to change any switches.
As above, take a photograph of the connections and post on here.
At least one of the blues has to be a switched live if it's a 2 gang switch.
Have you decided on which system? Some may work without a hub, but most need one.
If it has a hub, you can control lights etc remotely away from the house over internet via smartphone. No hub systems will only work within the house.
24E3F4F3-E270-4908-9CFB-86A645E0F833.jpeg BFCB50C1-1292-4FA6-BDDD-8C0A4B2B123D.jpeg FA960DE7-9861-4F8E-9E09-C805138683EB.jpeg Hi thanks for the reply’s im looking at the sonoff switches as they dont require any hub. Here is a few pics of the switch
Smart switches normally need a neutral at the switch to give them power to operate. Your switch doesn’t have one.
It may be that the Sonoff doesn’t need one, but you’ll have to check.
Those blues should have been sleeved brown to identify them as live conductors
and those green/yellow snakes should be 2.0mm, and a bit longer to cover the bare copper. :(:(:(.
Not sure one of them is actually connected anymore. The threads are totally stripped on the cover screws.
If both of the lights are on the same circuit (protective device) and you have access of the other end of the cable ie. at the light fitting it could be possible to alter the wiring to have a neutral at the switch.
looks like it's been done by a wqet-pants. 3.5mm thread stripped, cpc's twisted ( like a plasterer's brain). typical new build. lowest price bodger gets the work.
There are two lights in the room both with 3 blue 3 brown and 3 earth. None tapped for switch live. How would i go about altering it so i have a live at the switch? Thanks
I thought that you wanted a neutral at the switch?
Glasgow
Smart light switch installation
gmac,
davesparks,
