Currently reading:
Sparx exams in Ireland
Discuss Sparx exams in Ireland in the Ireland area at ElectriciansForums.net
G
gerryrowe
Can anyone offer me some advice?After starting my apprenticeship in 1998(thats a while ago!)and almost completing my apprenticeship in 2002,and through various problems both in my control and some not,failing subsequent repeats,4 in total,Im now trying to get my phase 7 exams repeated,the course in full if I can,as Im a bit rusty,has anyone done this before and can anyone offer any advice so I can finally get me trade cert!Thanks for the help!
Hi,
I dont think FAS will let you attend phase 6 again (phase 7 is on the job so I presume you meant phase 6).
Your best bet would be to contact FAS, I would say they will recommend that you take grinds and repeat phase 6 exams.
Good luck!
Conor
well you have maxed out on the repeats. However I don't think that FAS will ever stop offering repeats once there is a backed up reason for them. If you had an employer in Ireland you could get them to write you a letter for another repeat attempt, although I'm fairly sure that you must have done this for the 4th repeat, as the forth requires a letter from the employer. However, if you have something to back up a reason why you may have failed on one of the attempts FAS will listen to you, they always do.
As the above post suggests give FAS a ring, but have some good excuses ready for a couple of the repeat failures, use the stuff that was out of your hands be honest but have some paperwork for them for example a sickness backed up by a doctors letter etc will do the trick.
Are you based in Ireland? if so there is a scheme to try to get some of the phase 7 lads over the line so that they can have a qualification. Worst thing you can do is to just ring them up unprepared.
Best of luck, there are grinds as mentioned before, and FAS will point you in the right direction.
Reply to Sparx exams in Ireland in the Ireland area at ElectriciansForums.net
