- Reaction score
- 0
Texecom veritas R8, lost engineers code, how do you factory reset. End user code works ok, but cannot reset without engineers code. can anyone help??
Discuss Texecom veritas R8, lost engineers code, how do you factory reset? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Something for nowt, eh? Doesn't seem interested (or bothered) after receiving the info.take cover off. disconnect mains and battery. reconnect mains, pres and release tamper spring 3 times. this should revert to factory codes. reconnect battery, replace cover. try codes 1234 and 4321.
I've just done this reset on my alarm and worked a treat and saved me over £100 so thanks for that telectrixtake cover off. disconnect mains and battery. reconnect mains, pres and release tamper spring 3 times. this should revert to factory codes. reconnect battery, replace cover. try codes 1234 and 4321.
...take cover off. disconnect mains and battery. reconnect mains, pres and release tamper spring 3 times. this should revert to factory codes. reconnect battery, replace cover. try codes 1234 and 4321.
Thank-you so much, you have saved me money and your time has really been worth it.
I shall donate some money on your behalf.
Thanks for this had to reset alarm after tenent left house without giving the code. What charity can i donate to on your behalf.take cover off. disconnect mains and battery. reconnect mains, pres and release tamper spring 3 times. this should revert to factory codes. reconnect battery, replace cover. try codes 1234 and 4321.
RSPCA or The Dogs Trust would be great. Failing that, my beer fund is getting low.Thanks for this had to reset alarm after tenent left house without giving the code. What charity can i donate to on your behalf.
Reply to Texecom veritas R8, lost engineers code, how do you factory reset? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
