J
JuniorSparky
Hi everyone,
I was thinking that it may be quicker if I cut the steel wire straight instead of junior hacksaw and twisting method. But I was wondering how hard is the steel wire in SWA cable! Is it similar to piano wire?
I guess snips will always do the task, but can I use side cutter or heavy duty side cutter?
Thank you
Hacksaw with a sharp blade is the best way by far. You're only going to get into bother snipping the armourings. When you snip them they are less likely to line up with each other properly. When they do that, they can end up not being held by the gland properly.
Take your time and practice the skill. You shouldn't need to twist the wires, just a simple bend should snap them off when you have ringed them properly.
Here in Geordieland where men are men, women are glad of it and the barmaids eat their young, we just use our teeth.
tried it once with side cutters, never again, its important to get all the strands the same, if you do it with cutters the cut ends will stick out at diff angles and probably diff lengths making it difficult to fit the gland properly, use a hacksaw. mark it with tape if you need a guide.
Or a Jubilee type hose clip ??
Can you not get them stripper tools (like plumbers use for cutting pipe) to do it? or do they just cut the black outer sheath?
Yes, there is one, though I've never used it.
The general consensus among sparkies seems to be that they are crap.
I would not recommend using one like we use for cutting copper tube as the cutting wheel isn't up to the job of cutting steel wire.
The jubilee clip trick is ancient, I thought everyone knew it.
Trev I thought that everyone new how great Mrs T (Maggie to her mates ) was, but you didn't. Jubilee clips is a new one for me, and judging by some of the replies I've read i'm not the only one. I thank Geordie Spark for his input on this because I have learnt something, and as you have confirmed his advice I thank you as well. I won't hold my breath for you to thank me for the education I gave you about Maggie, but that's the kind of guy I am.:smilewinkgrin:
If you only do the odd one here and there and the OD is less than 19mm, i can highly recommend a Wickes ratcheting pipe cutter, works a treat till the blade goes blunt, but you will get a hundred or so cuts if you don't rag it to death, not bad for a tenner.
Thanks for all the replies. I will do some more practice with hacksaw, so I can improve my technique and speed then.
I haven't thought about jubilee clip. It sound like a good alternative to the tape. Whatever you have in hand.
There is now way on God's earth that you're getting what I've got in my hand bonny lad !!! ;)
Small tip for you JS and very handy believe me :)
Before you take the hacksaw to the sheath/armour make sure (for all cables up to 35mm'ish) that you put the final bend in the cable to the gland position first.
Meaning..............if you do your cut on the armour then 'snap' them off............then bend the cable into position..........you'll find the armour on the outside bend radius is significantly shorter that the rest.
Then you get the snips out lol :)
I forgot my manners, sorry Specs. I thank you for attempting to brainwash me into accepting the right wing propaganda concerning the late Mrs T and perhaps I should apologise for not swallowing it because I know the truth.
How's that bonny lad?
We mates again?
We mates again?
Trev, I'm guessing that is the best I will ever get from you re Mrs T, so yes , we are mates again :angel_smile:
I have been using the blade runner tool for five years now on Swa and find it a lot easier than a hacksaw. Most wholesalers can get them for 20 quid
They have those 'bladerunners' for cutting and stripping SWA but most reports I've heard on them is that they're Sh*t..I tend to use a Hacksaw but sometimes used an adjustable Pipe cutter/ringing tool for it...does the job luvvly :)
Bladerunners are great! Their downside is that they only do up to 35mm 4 core but then any higher and that's what a grinder is for!
This was a lil 16mm submain I was running the other day, stripped and ready for glanding in about 60 seconds using a blade runner. I defy anyone who tells me that they can do a job as neat as this (cutting wise) with a hacksaw!!!
Slightly misleading photo, it is cut to the same length so it sits perfectly flush to the gland. Looks crap IMHO when you've got an inch of sheath showing past the gland.
Here we go, top left, you can see what I mean:
Edit: And before any of you ice creams start with the "Mehhh, the banjo's not drilled through the body blah blah bleeding blah" I don't care! :D
Nice job......I hope it paves the way for others to follow
I was only endorsing the bladerunner but thanks bud :) If a job's worth doing, it's worth doing properly IMHO.
The amount of chewed up SWA and crappy glanding I find on a daily basis makes me want to cry sometimes! It beggars belief how some people can make such a hash of something so simple!
If you have to do swa regular, its worth getting an SWA stripper from TLC or similar - do a practice run first, then perfect cut every time, £17.95 with spare blades- its the dogs ********..
Where would I get one of these bladerunners? I like the look of that and it sounds like it's quicker too
from Tender Loving Care and yes, they do the sheath too.. stop turning the tool when the sheaths done, then move it along to do the armoured wire, move it along again to do the inner etc etc. until you've cut thru the cores- then start again!!
I don't get on well with the bladerunner it works ok on larger cables but tidlers it's rubbish, I tend to use an SWA saw :)
i find i now need to use a hacksaw as my teeth are getting blunt from years of using them on SWA. :74:
Tool for cutter the steel wire of SWA cable
Electrical Tools and Products
JuniorSparky,
nicebutdim,
