Hi,
Through other posts on here I've diagnosed a problem with the capacitor on my Beko tumble dryer. The problem is, now I have opened the panels up, the capacitor is soldered at the pin connections rather than having crimped attachments. Am I alright to snip the wires and solder them to the new capacitor? If so, do they have to go to a specific pin, or does it not matter? No sign of any identification marks.
Cheers
depends on which capacitor it is. could be electrolytic, in which case polarity matters.
you can solder them , but make sure they go on the same termials as before. be a good idea to fit some heat shrink sleevin over the connections.
How do I know which is the correct terminal? Both the old and new one have no defining features to tell me where to put them
looks like it 2 capacitors . need clear pics of both the label on the can and the connections on the ols one.
right. that clearsit up. it's 1 capacitor. it was seeing the other pic. looked like 3 terminals. leads can go either way round. it doesn't matter which way.
but we d
Which is what I said in the first place.
It's an AC motor. AC doesn't have polarity.
idn't originally know what it was. it could have been a smoothing capacitor on the PCB. original pic appeared to have 3 terminals.
Ab56 1ja
Tumble dryer capacitor
Electrical Appliances & Whitegoods Forum
Thread Tags
IslaView,
IslaView,
