Discuss Two test leads, one port in the UK Electrical Forum area at ElectriciansForums.net
I can't understand why everyone is so confused. Sometimes you want to do some test or another from A + B to C. For an IR test that might be L+N to E, or L1 + L2 + L3 to E or whatever, which if you have stackable test leads, you can achieve by putting one clip on each conductor and stacking / piggybacking the leads if they are stackable. It reduces the number of things that might come apart or ping off during the test, vs jumpering with separate croc clip leads. In electronics lab work, joining, branching and daisy-chaining test leads is normal so most bench test leads have a piggyback socket.
I keep a set of touchproof stackable leads and probes in the testing kit to make up whatever configuration is required. They are only for dead tests though as they are not CAT III rated.
Ah, Lucien's post has helped. The wording of the question made me think the OP was trying to do some sort of different test by using both ports of the MFT.
Oh yeah, that's a good idea :D
I was always under the impression that if you individually test L to E, and N to E, without joining them together, you basically do the same test, just without the hassle of having to use piggyback leads or disconnect stuff?
But if there are hidden loads on an existing circuit being tested for an EICR, not joining L & N together could inadvertently apply 500V across the load and cause damage. Best to test both to earth at once if unsure.
Reply to Two test leads, one port in the UK Electrical Forum area at ElectriciansForums.net
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hello fellow sparks, I’m looking to do my testing and inspection course which starts on the 30th of April, but I have not got much testing...
Evening all, Installed many extractors, but this is a first for me. Customer wants the fan vented out through the soffit, with an inline extractor...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Hey guys, I've been on jobs splicing and installing Pot head Terminations of 13800V PILC cable and I cant help but think our mix of lead to tin is...
