Pricing up a job in a factory and have to wire in a 3 phase supply, just going to double check my cable sizing i calculate i need to use a 10m cable
Swa cable clipped direct on its own , 35m run feeding a unit needing a 3 phase 20amp supply am i right ? just seems a little on the heavy side ?
top of my head 2.5mm is on the limit of VD. 4mm or 6mm is adequate.
Thanks David , coming in at a more sensible size now knew that looked far to heavy
- - - Updated - - -
4mm is the baby was some how working on the wrong volt drop allowence
Cable type: 70 deg.C Multi (armoured)
Fixing method: Clipped direct
Protection device: CB typeC
Protection rating: 20 A
Cable size: 2.5 mm
CPC size: 2.5 mm
Current carrying capacity of cable in this instance: 25 A
Final circuit: Yes
Ambient temperature: 30 deg.C
Number of cables grouped: 1
The cables are spaced
Voltdrop: 2.62 %
Allowable voltdrop: 5.00 %
Length: 35.0 m
Calculated R1+R2: 0.519 ohms
Calculated Zs: 0.87 ohms
Maximum Permitted Zs: 0.92 ohms
Type of system: TN
Supply: Three phase at 400 v
Ze: 0.350 ohms
Fault current: 0.26 kA
Applied correction factors:
Ca: 1
Cg: 1
Ci: 1
Cc: 1
Using a app I have it says 2.5mm2 is fine, although I would personally use 4mm2
with 2.5mm i get vd of (18 x 20 x 35)1000 = 12.6V , just over 5% then you have to allow a bit for the outgoing cable/s on the load side.
sorry, wrong column. 15mV not 18. so VD = 10.5V so acceptable.
Gloucestershire
Volt Drop
huntos33,
telectrix,
