Discuss cooker switch above hob in the UK Electrical Forum area at ElectriciansForums.net
I went to look at a job last night where the customer wanted advice about fitting a new hob.
She'd already ordered one from john lewis but when they arrived to fit it they refused as the cooker switch was directly above the hob (bottom of the switch 600m above). Said they couldn't because of "new regulations".
Obviously i would never fit a switch above a hob on a new install but as this is an existing install would it be acceptable to fit the hob anyway. Ideally the switch should be moved..but to do that I'd have to take off about 3 tiles (no replacements), a wall unit to (to access the cable run) and I'd have to extend x1 10mm t&e cable (supply) and x2 6mm t&e cables (loads)
I guess the other option is to do away with the switch join the cables and fit a blank but can't really say this is improving matters.
She's had the appliances refunded but wanted to know if I could fit the hob. gut feeling is no but not sure what others would do.
Cheers
In years gone by, it was the norm for the cooker switch to be above the cooker.
If I was doing an EICR, I would code it a C3, and yes, I would connect the hob but discuss the issue with the client first.
tin hat on.
I had the same issue with a well known company who fit kitchens,they redesigned the kitchen and fitted the cooker directly below the switch.previously it had been off to one side,they said that it wasn't a problem however I cited the reg about external detrimental influences as being a reason why they should not have done what they did.However the important thing in your situation is to remember that new regs are not retrospective,while there may be a reg now saying that you cannot locate something in a particular position this does not mean that something existing needs to be changed,however whilst I would agree that siting an isolator directly behind the hob is not ideal there may have been nothing preventing this in the regs at the time the install was originally done.
morning Phil pretty damned good here, enjoying my morning coffee before I head out into this beautiful day :)
How is Phil?
The issue here is the cooker switch maybe existing but the point of the cooker switch is for isolation in what could be an emergency like a fire, boiling over fat etc on the hob. Now any isolation point where access to it would require you to reach across the hazardous situe' you are trying to stop is obviously very dangerous and puts you at unnecessary danger, so any company fitting these hobs would have to make sure that in doing so the owner can safely isolate the hob in an emergency without having to reach across the danger.
The problem here is the owner should have been made aware of this at point of sale that additional works may be needed, if you buy say an electric shower that requires RCD protection as manufacturers recommendation and you are just replacing an old shower without rcd protection then you have to ensure the circuit is updated to meet the requirement, IMHO I believe this falls within the same kind of scenario.
Cheers
It could be if you took a cable from the cooker outlet plate into a base unit cupboard, fitted a cooker isolator to it within easy reach of the opened cupboard door then fed the cooker from that .... maybe??
Don't crucify me ..... I'm only a poor plumber. :sad_smile:
It could be if you took a cable from the cooker outlet plate into a base unit cupboard, fitted a cooker isolator to it within easy reach of the opened cupboard door then fed the cooker form that .... maybe??
Good move Geordie, done it a couple of times. Another "get out of jail free card" is if the C/U is within 3m of the hob. Classes as local isolation!
c/u is in same house. if that's not local, what is?
8 times out of 10 the C/U is in the kitchen anyway, ok it may be 4.23 meters away but at the end of the day "can it be turned off in case of a chip pan fire" (do people still have chip pans these days?)
Anything within the kitchen that is easily accessible is ok with me, as above, its local enough to be safe.
13.97654 ft. is that more precise? at least you can visualise feet.
Yes!! .... You got a problem with that?? :angry_smile: .. :)
Reply to cooker switch above hob in the UK Electrical Forum area at ElectriciansForums.net
