Discuss Need help at Emergency central battery in the UK Electrical Forum area at ElectriciansForums.net
س
سلطان سيف الدين
please i need your help to understand how can i make maintained or non maintained emergency luminaires . i want to ask about programming of CPU in ECB. is that responsible to make maintained or non maintained emergency lighting or not ? if not tell me what is using of this programming in CPU and what is the utility of change over module .
Why would you want a cpu within an emergency light, even analogue addressable em lighting systems don`t use cpu in the fittings.??
Here in UK you can get light fittings with emergency option, they have connection for permanent live and switched live, each light has a little battery built in, kept on float charge when power its on. when power is lost they switch to emergency mode. simple and easy no need for cpus and programming.
Reply to Need help at Emergency central battery in the UK Electrical Forum area at ElectriciansForums.net
