- Reaction score
- 5,659
I have been fault finding today.
The problem was fairly common. 3 switches (on different landings) switching one light, so 2 2way switches and an intermediate. The problem was that sometimes each of the switches worked and sometimes they didn't, so sometimes you have to go back upstairs and switch one of the switches off so that the downstairs switch can switch the light on etc etc.
I enjoy these faults as it just a matter of drawing out the circuit and seeing where it has been wired incorrectly.
However, this circuit was wired correctly. Nothing fancy, just a basic twin and earth from the light (PL and SL) to the first 2 way switch and then 3 core to the intemediate and another 3 core to the last 2 way switch... and it was all correct!! So I then tested each of the switching mechanisms on each of the switches and they all tested fine. Wired it back up, thinking perhaps just a connection problem - perhaps the terminal was just on the sheaving of the conductor (long shot) and the fault was still there.
I then bypassed the intermediate swith and it worked as it should. Replaced intemediate and the fault returned. Replaced intermediate switch with one from the van and it all worked fine!!
What I cant understand is what could be wrong with the intermediate switch as when I tested between each of the terminal blocks in the switch they showed continuity (as they should) vertically (and no continuity as a cross shape) with the switch in one position and then continuity in a cross shape (and none vertically) when switched in the other position (as they should)??????
