wetpants strikes again!
Reactions: 2 people
A kitchen extension I was doing at the beginning of the year.
The plumber thought it would be a good idea to mount his pipes dead in front of my box.
He then decided that he's pipes were more important than my cabling
And to top it all, my carefully measured down light positions were ignored and again my cabling totally ignored.
After having a word with the house owner, a new plumber was employed and pipes re-installed.
Came across a garden lighting install today with a few issues. How about this for an easy way to terminate the SWA, saves all that messing about with metal boxes and banjos or piranhas!
Is that an armoured ? Lol
Yes, I had to check, you can see all the cut-off steel just below the plug.
The other end is just as neat, cut-off steel again, and bare inner wires (the inner sheath removed) to light fitting, open to the elements and any passing wildlife that fancies chewing them.
Is that a 1mm from the top of the socket ?
Yes, the socket is wired in 1mm 3-core and earth ..., oh and it's a spur off a spur on a 30A fused RFC ...
Reactions: 2 people
That sounds fairly typical,seen 1mm 3 core/earth used fairly often for sockets , is it because it's similar to 2.5mm in external dimensions to the DIY 'experts'. :icon12:
or more likely it was wired by a muppet in first fix and by the time second fix came along it was too late lol
Reactions: 2 people
Reactions: 3 people
Isn't it an SWA into an old MEM or similar metalclad switch ? If so and the SWA is a two core then it's worse than we thought ! :uhoh2:
Reactions: 2 people
Agree, thats an SWA - you can read the voltage dialectric value on the side.. I would suggest that isn't a swa gland and in fact the pvc is cut and the clip is bonded to the steel wires.
Yes I'd agree, the removed outer sheath is hidden in the picture by the earth strap label.
PV install on a garage roof and the new build garage has a SWA feeding it! Brilliant, easy to feed into the Grid!!!! Then we looked at the other end..........
SWA fed from a plug top, plugged into an extension, plugged into the hallway socket!!!! Only just had enough space to fit a double pole Iso in that cupboard.
Spotted this on an Eicr a couple of weeks ago!! How not to get a water pipe into a porta kabin.
Reactions: 5 people
To be fair I i didnt entertain looking inside to confirmhow many cores Dave OCD. I was looking at this after a boiler house refurb that made me chuckle.
It has been done with such precision, the labels are neat and readable, the clamp looks tight, the bonding cable cores are continuous and then... they missed the pipes!
Reactions: 2 people
Customer making full use of the new USB sockets they asked for ......
You managed to mess up the wallpaper a bit there Andy. :smilewinkgrin:
Ha, only a bit. You don't have your name for nothing I see.
The original conduit stopped an inch before the box so had to knock out a bit of wall to rewire. If you think that's a mess you should see the rest of the house !
8K
Darkwood,
mainline,
