wetpants strikes again!
Reactions: 2 people
A kitchen extension I was doing at the beginning of the year.
The plumber thought it would be a good idea to mount his pipes dead in front of my box.
He then decided that he's pipes were more important than my cabling
And to top it all, my carefully measured down light positions were ignored and again my cabling totally ignored.
After having a word with the house owner, a new plumber was employed and pipes re-installed.
Came across a garden lighting install today with a few issues. How about this for an easy way to terminate the SWA, saves all that messing about with metal boxes and banjos or piranhas!
Is that an armoured ? Lol
Yes, I had to check, you can see all the cut-off steel just below the plug.
The other end is just as neat, cut-off steel again, and bare inner wires (the inner sheath removed) to light fitting, open to the elements and any passing wildlife that fancies chewing them.
Is that a 1mm from the top of the socket ?
Yes, the socket is wired in 1mm 3-core and earth ..., oh and it's a spur off a spur on a 30A fused RFC ...
Reactions: 2 people
That sounds fairly typical,seen 1mm 3 core/earth used fairly often for sockets , is it because it's similar to 2.5mm in external dimensions to the DIY 'experts'. :icon12:
Reactions: 1 person
or more likely it was wired by a muppet in first fix and by the time second fix came along it was too late lol
Reactions: 2 people
Reactions: 3 people
8K
Darkwood,
mainline,
