Apologies for what will seem a daft question to you guys - I am not an electrician, and have not got to grips with the different voltages on appliances.
Can someone tell me if these lights can be wired into the mains - these state 110v so if not would these usually be powered by a generator or transformer.
Again apologies for my lack of knowledge.
Vince
If you stick 230V it will damage the light as well as being extremely dangerous, where did you get the fittings from? so DON'T connect them up to the 230v mains
I believe construction usually use 110v (I may be wrong), so where would use a bulkhead emergency light like this ? I think its an emergency light anyway - although it does not have a battery of any sort inside
if they are emergencies, on loss of the lighting circuit supply, the emergency supply would kick in. 110V would mean less batteries to supply them.
Thats what I thought, however what makes them emergency lights as opposed to standard 110v bulkheads if they are powered from an external source surely a normal bulkhead would work the same
Some older emergency light systems have a central battery instead of batteries in the lights. Ones I have seen in the past have been the size of a tea chest if you are looking for one on site.
what exactly does that mean Andy when you say slave - do they need a "master" of some type to work?
Yes, the master would be a 110V central battery system that Tel alluded to in post 6. Slave fitting seems to be the common description for these. This differentiates them from self contained emergency lights which have the battery built in to the light fitting.
If you know the manufacturer is Glamox, you could call them and ask them for more info. Are there any product or serial numbers ?
The number states GS/L3/SM/8/110/LSOH
8 will mean 8W tube, 110 will be the voltage, LSOH means low smoke zero halogen and will probably pertain to the plastic casing the bulkhead is made from.
If you ring Glamox with the code they will tell you exactly what it is, but it's probably as said.
they're worth whatever someone is willing to pay. £14 sounds reasonable, but it's a limited market. suggest you find out the cost new, then base on that. say 50% of new price.
Essex
Wiring Bulk Head Lights
VincentW,
telectrix,
