Gavin, maybe you could use a normal FCU in the office then come out through to a weatherproof switch, a bit more roomy for the SWA and gland ?
I have considered that. I have a good variety of IP66 accessories in the back of the van somewhere (it needs tidying!) so will have a play around with various combos and go with what works. Just dont have a outdoors FCU.. dont tend to use them much... It will though be either a FCU or switch in the greenhouse area for isolation purposes. as sometimes the office is locked off but somebody is in the greenhouse area working.
Reactions: Dave OCD
I can pull a flex out of any cord restraint you care to use.
Without seeing the full environment how can you know what strength of cord restraint is required?
Stuffing glands are provided as the means of cord restraint on a variety of trailing plugs, sockets and IP rated cable joints, are all of those manufacturers wrong?
If correct cord/cable restraint is employed I doubt you could pull out any one would care use use without causing physical breakage.
  • Dislike
You could pull the cable put of most JBs with cord grips. What are you trying to prove?
Reactions: Rpa07
A correctly employed clamp will stay in place unless you physically break it.
I'm out.
Usual forum issue.
Empty 1 Gang and 2 Gang enclosures are common. Most manufacturers make them. Can then fit whatever you fancy inside them.
Gavin John Hyde
Patron
Somerset
Website
http://www.sulis-electrical.co.uk
Business Name
Sulis Electrical Services Ltd
external fcu question
Gavin John Hyde,
