Discuss What type of light bulb is this? in the UK Electrical Forum area at ElectriciansForums.net
Hi all
Thank you for registering me.
I have a flickering ceiling light. I took off the shade to get at the bulb but the bulb is one I've not seen before.
What kind of bulb is this?
Many thanks
Chris
It's just an led version, looks like it'll be a G9 fitting. If it is it will just pull out and have two oval pins like the image below:
If you try gently and it doesn't pull out it will either be small screw in so twist anti-clockwise or bayonet- push in and slight twist anti-clockwise.
Also looking at your existing bulb it appears to have live and neutral connections exposed so power off before before you touch it- I've seen reports of people getting shocks from badly made led bulbs that have live parts exposed
The Philips head screws look to be fixing the PCB to the heatsink.
If post #2 doesn't help then post #4 is the most likely scenario and a new fitting is required.
If that is a chandelier type fitting is there a centre connection where they are terminated together, and possibly a bad connection.
Reply to What type of light bulb is this? in the UK Electrical Forum area at ElectriciansForums.net
