Currently reading:
UK Ceiling light replacement
Discuss Ceiling light replacement in the UK Electrical Forum area at ElectriciansForums.net
Tiddler
Hi I'm changing an old ceiling light but I have more wires than I was expecting. Please see the pictures below.
If I leave the connection block with the red cables in and then buy some connection strip the same as what the red wire is connected to can I just attach the 2 black wires to the new live wire and the single black wire to the new neutral wire?
Any help will be much appreciated, thanks.
you leave the 3 reds as they are. no connection to the actual light. the single black is light live. the 2 blacks together are the light Neutral,
Thanks for your reply but is the single black not neutral looks like its doing to the blue? Also can I just connect the correct wires from the new light fitting using some connection block?
Unless its my eyes (more than likely) I can see the cpc's twisted together (earth conductors) these will need to be sleeved and go into a connector block (preferably wago) of some sort. I'm guessing the last image is for the new light and is more than likely double insulated / class 2? If not, then you may be required to extend the cpc to an earth connection in the new light.
Reply to Ceiling light replacement in the UK Electrical Forum area at ElectriciansForums.net
