Darkwood
You’re onto a winner 🏅 today with that lot. 👍
What’s more amazing is the customer is adamant it’s not DIY. He had another electrician in who left the job half way through and hasn’t been back in touch. 🤔 I’m guessing he’s fell out with ‘Dave from the pub’. 😂
I’ve disconnected the lot. Initially he was a bit miffed I’d disconnected it all. But I said that’s what needed to be done as it’s not safe. Explained to him a few options of how it can be resolved and he’s asked for a quote and when I have availability.
That’s good that he’s been reasonable about you disconnecting it and wants you to do it properly. It looks a right dogs dinner in those photos.
Where's that what looks like swa in the meter cabinet come/goto
That’s the SWA for this abomination. It goes to the fused spur under the consumer unit you can see in one of the pics.
Not glanded anywhere, not that it matters as they’ve peeled the armour back to shove it into the box with the 3 core & earth PVC cable. 🙄
Ahhh I was wondering because it's following the dno cable I thought it may have been a bypass didn't realise it's looped through :)
Asked by a relative to change a light switch. OK no big deal, unscrew the two fixing screws as usual, pull them out...and out...hmm by time over 5cm of screw has exited I was not expecting great things:
Now they have identified black as (presumably) switched live but yes that really is polystyrene bulking up the wall with the back-box recessed by several cm. Chock block probably all that existed at the time (done at least 16 years ago) but also not visible is the bottom left corner where the earth tag screw was just spinning and no gip of the CPC at all.
Nothing like the sort of other crap that makes it here, but not my ideal job when not prepared to actually fix it properly. Best I could do at the time was to use on of the woodscrews to retain the CPCs.
Just use one of the upper or lower 3.5mm plate fixing screws.
Had I known the state I would have planned on a new backbox and maybe tried to space it forward so the normal (as supplied) screws would work. I just happened to have new 5cm ones (bizarrely enough, from another job a year ago where they turned out not to be needed so I left them in with small tools in car) so they did get clean screws as well as a new paint-free switch.
You can get extension collars for back boxes in various depths from any good electrical wholesaler, easier to fit than it is to try and remove a backbox without damaging the wall or just opening up a can of worms
Was this ever allowed? Using an earth pipe clamp on the armour of SWA?
This is in the gymnasium I’ve been doing little jobs in. Main bond goes to water pipe… a little too close to a soldered joint for my liking…. Then onto the SWA, then onto a gas pipe.
It wouldn’t be so surprising, but the building was used by an electrical firm before the gym bought it.
The other thing, although I wasn’t working on it, I cannot find the fire alarm panel.
There’s break glasses and sounders, wired in surface red fp… but I can’t trace where they’re going over the ceiling of what was the offices.
Covered in insulation.
Funny thing is, the owner says it passed any fire safety check when he bought it. They must have just looked at the detectors and sounders and assumed there was a panel for it all.
(There is an RCBO in the board marked up for fire alarms)
Looks like a lazy way to bond the pipework
It could be an old 240v mains fire alarm, they were quite popular at one time although I've not seen one for many years as most were changed over to operating with a panel, so beware if doing any work on the fire alarm the break glasses may have mains voltage present
I considered a mains operated system but the use of FP200 cable and what I assume are modern automatic detectors probably rules this out.
Is it FP200 or assumed to be FP200 and the reality is it is FP100 which was a horrible cable which if not terminated with the ferrules quite often failed
It could even be pyro at a quick glance
I’m not there now, but take photos when I next go back.
They are fairly modern call points and sounders, and I only assumed it was fp200 as it certainly wasn’t MICC. Red compression glands into plastic boxes.
I did run my non contact tester along the cable and it wasn’t lighting up… so I expect it’s ELV
Like I said, I wasn’t working on the fire system, so there was no need to shut it off.
I used to go to a youth club thar had been burnt down in an arson attack.
When we eventually got it back completely rebuilt apart from the thick stone walls it had all nice shiny break glass fire points all over.
Problem was non were wired in to any thing.
I think FP200 cable has a foil layer that is in contact with the CPC so I would not expect any electrostatic potential enough to trigger a non-contact probe outside it. You would have to try and some junction where the cores are exposed.
It was the original FP200 which used the ferrules to prevent the sharp edge of the foil layer damaging the insulation.
FP100 is single insulated fire-performance cable for use in conduit/trunking.
8K
Darkwood,
mainline,
