- Nov 30, 2021
- 3,333
- 1
- 2,923
- 3,247,381
- United Kingdom
- Business Name
- Mainline services
The original tails are most defiantly buried and unless they are protected they won’t be compliant.I do think with some extra finesse, he definitely could have hidden the cables.
Did the meter tails originally goto an isolator ?.
The tails from the meter are very short.
I would have liked to have seen either an isolator or Sp+n fused unit there although not really allowed to use the cabinet for consumers gear.
