OP
Adam W
So can you get out of having to notify work in kitchens and bathrooms by screwing the fittings to the fabric of the building?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Discuss Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
So its an EIC then and not a minor works, due to upside down rain.
For some reason I am now singing purple rain.......................
no, becasuse that's special location. see malc's post#50So can you get out of having to notify work in kitchens and bathrooms by screwing the fittings to the fabric of the building?
(i)
The installation of equipment attached to the
outside wall of a house (for example security
lighting, air conditioning equipment and radon
fans) is not notifiable provided that there are
no exposed outdoor connections and the
work does not involve the installation of a
new circuit or the extension of a circuit in a
kitchen or special location or associated with
a special installation.
I would say that Tel was right and it is not notifiable, as long as it adheres to above taken from the Part P silliness.
the bit about exposed outdoor connections. one could argue that this would make a socket outlet notifiable, but then if it was IP55 with a flap on, there's then no exposed outdoor connections, so it would be non-notifiable. typical part pee confusion.I re-read this and would agree with Tel. Less money to pay Elecsa then as I've always notified outside lights!
I stand corrected.(i)
and the relevance to all things electrical is ???????squirrels are well known for attacking nests. If you do a web search on how to deter them you may come up with something.
nope not all outside fittings are ip 4 rated some are only ip2 so not such a stupid answer was it. know it all
Reply to Lights in porch soffit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
