doubletiger watch the moneysaving comments they all seem to be talking about what I call the £250 cowboys who turn up change it over no documentation dont bother about earthing and if there is a fault sometimes they are on this forum looking for free help to fix it
Please see two additional photos
it is clear it bonding to gas pipe from 1st photo. I think it also bonding to water (black from bottom of board), may be yellow bonding it (behind the board)?
If it bonding to both gas and water, do I have to replace these two old fuse boxes?
thank you for advice!
That looks like you have no earth spike in the ground and are relying on the gas and water for your earth. Definitely get it checked by an electrician.
doubletiger...!
Agreed with many of the other comments, Gas Water looks Fine, Just need an Main earth Now....
as for getting quotes...! stay clear from them sites that give you 4-5 quotes, tey are a scam and SELL your details to contractors who then quote low and do a crap job!
please type your postcode in this government agency site!
Competent Persons Register | Home
this will ensure you get a registered electrician
Top Cat -- "have no earth spike in the ground", I think you are right, I cannot it.
DurhamSparky -- thank you for website link.
My question now is -- Should I just install earth spike into the ground and leave others intact?
of course, I will use a competent person to do it for me.
thanks
honest answer...
replace the lot... depending on budget install RCBO rather than a split load dual RCD unit..
thanks
First and foremost, contact your area DNO company and ask if there is PME (TNC-S system) available in your area. I would imagine there would be, being in South London, (...Bromley wasn't it??) This will give you a far better earthing arrangement than, relying on a an earth rod (TT system) installation
If you do have to go the TT route, make sure the electrician uses 2 X 5/8'' extendable coupled rods, and not these thin 3/8'' twigs that a far too common and basically useless!!....
