M
Mattbot2
Hello,
I have a single socket in the corner of my bedroom, i would like to replace this with a double socket. Can anyone advise me on how i would go about doing this?
Thanks,
Matt
Hello,
Thanks,
Matt
plug in an extention lead matey its easier;)
I'm unable to do this as i plan on using homeplugs. Homeplugs are for computers, they send data across your houses electrical lines so that it is essentially wireless. These get interference when used in conjunction with a surge protector, as i am using.
Hello,
Thanks,
Matt
Unless you are know what you are doing leave it alone and get an electrician in to do it.;)
A little knowledge can be DANGEROUS.:eek:
You can get sockets that double up (or more) called converters that you change your existing socket for. No chasing to do.
1G to 2G Sw Skt Conversion Kit - Screwfix.com, Where the Trade Buys
However, you should be competent in doing this type of work. If not call in a sparky.
Which one of these two should i get?
Pay your money, take your pick. Go to screw fix and have a look at them. If you have any doubt about fitting this contact a electrician.
Hi mat,
i am in the same situation you are in. Did the socket adapter hinder the speed of the powerline?
Mattbot2,
shocking_eg,
