Hi Guys,
Anyone have or know where I can get a hold of a copy of the manual for an Accenta 8 Mini Alarm Panel, preety old system so im finidng it difficult to get a hold of the paperwork. I have received two seperate calls this week about faults on these panels one of which is fairly baffling so I could really do with the manual!
Cheers
Dave
what's the fault? mostly, these are simple to sort. i might be able to send you a pdf.
One of the faults shouldnt be to much trouble, external sounders not sounding, the other however is more complex, the alarm is sounding regularly of its own accord, and the homeowner seems to think that when she turns on light switches they set it off. I was wanting the manuals as I have asked her to record the code on the panel when the alarm sounds.
If you could send me a PDF version It would be much apretiated!
sent email with pdf attached. as for the lights affecting the alarm, try a snubber across the L-N in the alarm panel.
Durham
Accenta 8 Mini Alarm Panel Manual
Security Alarms, Door Entry and CCTV (Public)
enlighting,
telectrix,
