- Reaction score
- 718
Has anyone purchased or fitted a plastic enclousure that will mount to the base of a street light pole, ideally in kit format?
Discuss Box to go on bottom of street light pole in the UK Electrical Forum area at ElectriciansForums.net
Bigspark17 I’ve used PVC boxes and bell boxes and it was a steel pole just drill and tap itHas anyone purchased or fitted a plastic enclousure that will mount to the base of a street light pole, ideally in kit format?
You can get a box with mounts on the back and straps to tighten around the Colum we've had to use them several times I'll see if I can try and find a brand for you.
[automerge]1575368137[/automerge]
This isn't exactly it but it'll give you an idea as it's very similar
Reply to Box to go on bottom of street light pole in the UK Electrical Forum area at ElectriciansForums.net
