Got a 5 ring ceramic hob, all ring power on and can select heat setting on them but only 2 heat up? On the flex there's 4 cores I've connected brown, blue and earth but have left black could that be anything to do with it? On a 32A Rcbo as required and fed by a 10mm which is plenty!
Yes! I would expect both L1 (black) & L2 (brown) to be connected for everything to work! Usually there are connection diagrams for different supplies (e.g. if you have 2 or 3 phases, as common in some countries).
I'd like to know what exactly is written on the label. Surely the manufacturer has stipulated a connection to 230V supply if this was purchased in the UK.
