Discuss Dead socket - finding the cabling in the Electrical Forum area at ElectriciansForums.net
Any tips / tools for finding cable runs? Sockets and outside light stopped working in an extension.
Experienced DIYer / renovator, doing some uncovering for my spark. What with social distancing and the fact that old horrible artex (ugh - will be replaced) might have asbestos - A lot of the uncovering is being done by people other than the sparky. Mostly me :)
1960s house with a flat roof extension for a ground floor bedroom with en-suite. The bedroom has two sockets at opposite ends, on a radial. One is working. On the other, the radial extends through the wall for a socket in the en-suite. Both these sockets are dead. Additionally there's an outside light which is also dead. Other lighting circuits are OK. MCB has no problems.
The house was built during a copper shortage. Some of the plumbing is steel pipe and spark has found aluminium twin and earth before now. We're hoping this is a potential cause of the fault, that it's come loose in a JB somewhere.
I'm really hoping there are no boxes above the ceiling in the flat roof area. Trying to find where the cabling comes into the rest of the house is not clear and lifting floorboards hasn't revealed much so far. To go further means dismantling built-in wardrobes.
It will be done if it needs to be done,
But I wondered if the experts have any tips?
OP
C
The landing is another challenge. It's most likely place for boxes etc. the floor boards have been fitted with hardboard sheets and grippers for carpet.
Except at some point the alarm installer ran cables over the hardboard. That's going to be fun.
Reply to Dead socket - finding the cabling in the Electrical Forum area at ElectriciansForums.net
Hello all, I'm new to this but seeking some advice. Just done an eicr, all lighting is white 1980s cabling, as is MOST of the power cabling...
Hi, I would like to add a new socket in the bedroom. Current room configuration: 3 existing sockets - wiring coming from the bottom (under the...
Now I only replace my phone when they need replacing but my old Samsung S7 kept freezing the other day then died. Took to a phone repair shop they...
Have a single plug socket which has been working fine for years. It is behind a unit so nothing has hit it. I looked at the socket and can seen no...
Hi the other day I opened the socket just to find out that 2 neutral wires were damaged with visible copper so I decided to cut them short and put...
New Posts (Please Reply)
