Dustydazzler
I still have loads of 5a & 15a screw connector block strips , I use the odd bit occasionally
just wondered if anyone else still buys & uses connector block or is it all Wagos now ?
Always have some in my toolbox.
Mostly used for temporary connections and links etc for testing and fault finding.
Rare to use it for a permanent joint, I prefer wago type connections for that
I have some as well, the fancy ones with the tab under the screw to avoid trashing the cable, but would generally recommend Wagos.
The screw terminals I do still use are the DIN rail sort, though you can get sprung clamp ones for that as well.
They have their places, but don't use them if I can Wago instead. Sometimes, as a temporary repair, they are ideal...I used one to connect a broken throttle cable on a Simca 1100 in 1974...perfect!
I always use wagos or if it's for a permanent joint, push fit crimps- handy for when cables are cut too short or break behind a socket outlet or fcu and you can't get to it with rachet crimps!
SIMCA??? SURPRISED THE EXTRA WEIGHT DIDN'T CAUSE THE ENGINE TO DROP OUT.
Does anyone still use connector block..?
Dustydazzler,
pc1966,
