Owner of house requires LED lighting in kitchen kick boards. Possibly those small diameter ones that I've seen on the odd occasion. Are there others that fix on the under side of the cupboard ( basement). would you wire these LED lights as you would an ordinary every day light point ie put light switch on wall with others that control the ceiling lights. If a driver used, house the driver behind the kick boards? As always, any tips / advice appreciated.
LED strip gives a good effect and is not usually visible if mounted at the top of the kickboard. Built in appliances can spoil the run of tape though so check first.
Switch from wherever the client wants a convenient switch point.
Driver/transformer can live behind the kickboard. The boards easily remove for maintenence although there is the argument of inaccessible connections.
I have a 13A socket in a cupboard which mine are plugged in to. I use a remote control socket so that I can switch them on and off as required. Daz
i like the idea of the strip LED lighting. i get the feeling that the circular ones over time will attract dirt around the edges.
i would of thought, if kick board is removable then access for maintenance, testing etc will be OK. If a driver used, surly that's the best place for it, isn't it?
Aggghhh the reason i asked was.......At home my BT box etc is housed within a cupboard. the remote will NOT work on it to change channels etc. When in use door is open. Luckily the door is in a corner so not too bad, neat and tidy when not in use.
remotes normally use ir, so even putting your hand infront or a piece of paper will stop them working
meant to put ir rather than rf
remotes normally use rf, so even putting your hand infront or a piece of paper will stop them working
Garbage. Most remote controls for tvs etc are IR. And a piece of paper certainly won't stop RF anyway. otherwise your radio wouldn't work in the house. Daz
i meant ir rather than rf XD
you can get the multismart remotes (cant remember the name)
look at hdnation on revision3 and there always talking about them and these use bluetooth or ir i think
im half asleep.
You can indeed get remote extenders that receive IR and send to a receiver over RF yes. very useful, I use one so that I can operate my Sky, etc while the cupboard door is shut. Daz
These are some of the ones I fitted to our kitchen - they are bright!
I ran the feed from switch during the refurb to the 3 locations I needed! Not sure about having an RF switch - I can see that getting mislaid!
Edit : These are from the Sensio range
England
United Kingdom
Retired Electrician
led lighting in kick boards
driverman,
Barry White,
