Discuss Light fitting no earth terminal and metal in the Electrical Forum area at ElectriciansForums.net
Hi, the new lights I have are metal and the earth connection doesn't connect to anything. I noticed the light that was there before someone had connected an earth to one of the bolts of the metal frame using a fork crimp. What would you do?
OP
Mark Wright
Sorry I've just gone to look for a class 2 marking and I think the earth terminal is connected to the frame.
It's just choc block on a laminated bit of paper but with closer inspection there appears to be a metal fork sticking out under the laminated card.
Doh.
LastManOnline
As long as you use the little connection box supplied properly, any loose cable cannot come into contact with the metallic body of the fitting.
well ,thats the theory at least.But in reality a loose cable (or damaged cable) could quite easily come in to contact with a metal frame.The concept of "double insulated" has (in my view) been diluted to the point where its almost meaningless.
Reply to Light fitting no earth terminal and metal in the Electrical Forum area at ElectriciansForums.net
Hi, Just interested in learning what others do when faced with an old lighting installation where there is no earth and you’re installing a metal...
Hi all, Would like some advice on the below. Context: Rural French domestic installation TT system Earth rod is situated inside the property...
Hi All Seen this on a few jobs now where they have on the Downlight fittings where the CPC is terminated outside the enclosure of the Downlight...
4K
Performing the PAT inspection on some science equipment and I have found some items that were passed by the previous company that performed it...
Hi guys wondering if you could help? I have just installed a new fuseboard with rcbos and spd. During the install I noticed that the lighting...
New Posts (Please Reply)
