Currently reading:
Moving from Domestic to Industrial
Discuss Moving from Domestic to Industrial in the Electricians' Talk area at ElectriciansForums.net
Hi
I've been working for Domestic clients for some time and I'm considering branching out to do Industrial work. I'm faced with the fact I don't know what I don't know, if you get my drift, so I'm after some advice. What other qualifications would you suggest above and beyond the below list.
City and Guilds
2382 - Requirements for Electrical Installations BS7671 17th Edition of the Wiring Regulations 2008.
2393 - Building Regulations for Electrical Installations in Dwellings
2392 - Fundamental Inspection, Testing and Initial Verification
2394 - Initial Verfication and Certification of Electrical Installations
2395 - Periodic Inspection, Testing and Certification of Electrical Installations
The skills you require cannot be had from any C&G course, you will have to learn them from others at the coal face.
The same would apply for an 'industrial' spark knocking plastered walls about. I wouldn't make a penny doing houses. I'd take 3 times longer then you would to rewire a house.
You don't have any core underpinning knowledge qualifications just add on qualifications. You should look at doing 2365 level 2&3, AM2 and NVQ level 3 if you want to further your personal achievements (qualification wise).
Thanks for the reply Lee. With your advice I'm not sure what my next step would be. I'm not going to shut my successful Domestic business and go and work for someone else. Pretty disappointing to hear that, is the only option.
Thanks for the reply Lee. 2365 looks like entry level stuff. I'm already qualified and have experience beyond this level.
Yeah but from the list of qualifications you've posted you don't have any core underpinning knowledge qualifications just qualifications that would usually be done additionally to the core ones. You would not be considered qualified in the eyes of the JIB as you would not be able to get an electricians grade. Along side my contracting business I also have a side line carrying out energy efficient lighting (daylight harvesting, presence detection etc) in industrial premises. Many of the factories we work in when you have a site induction you have to prove your qualified by producing your certificates or JIB card as they wouldn't want/allow a short course "electrician" loose on their electrical installation. So if you want to do industrial work I would gain the basic qualifications to allow you to be graded as an electrician first.
I'll second Lee's post.
I was let loose on Chemical and Pharma sites as an Instrument Tech with none of your qualifications, but, I did have a degree in Electrical Engineering! :)
Maybe think about about expanding into the Commercial sector?
Many years ago I started on a pharmaceutical site. On the same day a guy who had just came out of the RAF after twenty odd years with qualifications as long as your arm. It turns out he could not put a nut in a monkeys mouth. Six months later I saw him off shore with a clip board in hand checking my work. The moral of the story is what do you want to do in the industrial world, install it or test it? There is a lot of money in testing!
Hello Chris
I am a Vocational Instructor and I train electrical and mechanical contractors in industrial electrical maintenance and fault-finding skills. However, I work for a company that has its own training department for off-the-job training and so any new employees requiring additional electrical/mechanical training isn't a problem.
So, you need to look for a company that has its own training facilities and willing to give you the training you need. Alternatively, you can pay for the courses you need but these can be quite pricey. It's practical experience you need; not more qualifications!!
Cheers
Ken
Id say you don't need qualifications just experience. I was once a solid house basher on large developments as an apprentice. I then had a go a industrial and found it to be a slightly slower pace and more thoughtful and now do the occasional plant work. If you want to learn more, keep your ears and eyes open and read some of the posts in this forum. Listen to the old boys as well as they had a more varied apprenticeship then we get these days, that said the apprenticeship route gives you all the underpinning knowledge its up to you to figure out the rest. I now enjoy industrial more as i am learning again, if i am stuck a quick call to some old boy in the office will put me right on sit. Never be afraid to ask is my motto.
When I started my apprenticeship, Electrical work was just that, everything.As Lanky said just get some experience in that field, do you know fellow sparkies in that field.?
You cannot buy experience, unfortunately that takes time. Domestic work is a tiny drop in the ocean and there is no short cut to gaining it.
Industrial all day long.. You can actually take pride in the work you do without the fear of a supervisor up yer ---. If there's not a lot of industrial construction work then commercial follows suit.
Try and get some experience with an " Electrician " that does Industrial work, There is lot more to industrial than Domestic JMO
Bizarrely in my experience it's a lot easier to get into industrial instrinent/electrical work than say become a scaffolder or rigger where there seems to be a legal requirement to be qualified. You may find going from domestic to an industrial maintenance role a fairly steep learning curve due to the variety of kit you will encounter. PLCs/valve actuators/motors/DC/HV/rotary converters
I remember my time on industrial sites, you get the drawing from the office and get sent up to an area of the 4th floor then the apprentice can get the conduit/tray/metal trunking/drills/screws etc etc while you look things over.
you got drawings? :O lucky sod
Come on Terminal 4 doesn't look "that" bad.........
i think i seen a drawing once whilst i was at the distillery, quick walk round with supervisor at start of week, what annoyed me was when i first started he pointed to a brick and said "drill here", i drilled there and then he decides it doesnt look right, so we opt for where i was originally going to take my hole out, that said the only thing i found different about industrial work was the containment and type of cables, bit more manual intensive, i eventually got put into the switchrooms, suited me fine, smoking tabbies and glanding up 140 odd 2.5 swa/FP
Swicthrooms, I remember building them especially the hydraulic ones, the mains risers where always fun.
I always enjoyed PYRO though, but I am a strange one......
Lee I agree with your sentiments, but whatever happened to the term "ELECTRICIAN" electricians should be able to do all 3 of the so called competencies or they did when I was an Apprentice, sorry it is the 21st century I forgot, easy come easy train to be whatever you want as long as you attend the right course.:D:rolleyes::po_O:mad:, not having a dig at you mate just venting my frustration.
The OP was talking 12 months back, Pete.....might be an expert in all 3, by now.:)
I'm a offshore electrical technician and when it comes to house bashing I am not very confident , terminating cables is easy but routing cables and keeping it all the the regs is another thing.
It's all about experience mate. Find another sparky who is more industrial and try and get some time under his wing and he would be able to show you the ropes.
I'm going to spend my time off the vessels working with a mate who is a domestic spark, hopefully will be able to learn the domestic side of electrics
Reply to Moving from Domestic to Industrial in the Electricians' Talk area at ElectriciansForums.net
