Discuss niceic minor works cert in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
I
iceman
hi on green minor works cert by niceic where its says circuit protective device for modified circuit witch in my case would be BS 60898 type b
thn under tht its says rcd if applicable does suggest if its used as a main switch so again in my case i would put n/A or do i need to fill in the details eather way any help would be great cheers
hiya
sorry I am not answering yr question butrather asking one,, i want 2 do NIC assessment, can i do for my minor job,, convert a single socket into a double and if so ,,what test wud i need 2 carry out
regards
hello tonytrying as fare as i know the niceic require you to add another socket to an exsisting ring final ciruit or new additonal light point to exsisting lighting circuit for a minor works, witch ever you choose to do, just changing a single socket to a double will not be enough hope this helps ;-)
yes he will want ya to carry out some tests to demostrate competence in testing you'll need to jobs for assesment at two different sites one minor works like adding a new socket to ring final and one major works like a c/u change or full rewire etc ;-)
You put the BS number of the RCD if there is one. If its a split load board and its fed by a 32A MCB but off the rcd side of the board you would put 60898 For your MCB and 61008 or 4293 for your RCD.
im unsure wot the bs number is for the rcd cos it dont say all i knw is its hagar 63a with a 30mA trip time its in a newly built house so my guess is tht it propley wouldnt be the older 4293 rcd wots thoughts on this? thanks
cdc263w-500
not sure if this worked but heres the web link www.hager.ie/index.php?scr=800&id=583 second pic down cheers
Is it exactly as the picture or similar?
Sometimes the BS number is in with a load of other numbers and can be difficult to make out.
This is a BS4293:
Excuse the pic. Done with fone.
And in your link is a BSEN61008
I have noticed on some devices nowadays that they dont list the whole number down, you may have something like BSEN008 as opposed to BS 61008??
Particularly with main switches - BSEN947-3.
thanks alot jason its not tht rcd you shown its deffinatly the one on my link thank again for clearin tht up ;-)
iv just noticed a problem on me rcds where the red patch is when the rcd is one its showin white thn when i press the test putton to turn the rcd off the red patch comes up its the wrong way round will me asseser fail me on this?
Reply to niceic minor works cert in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Evening all, I just wanted to see if electrical improvers/adult trainees with appropriate levels of experience and who hold testing...
Hi, I would like to do some minor domestic electrical work while I am completing my NVQ level 2 in electrical installations. I have the 18th...
5K
Hi, can someone give me some advice RE completing a small works certificate for a fused spur coming from a ring final. 1) In part 2 of the AMD2...
7K
As above ,does any of the following work require a minor work cert, changing MCB's, changing sockets, fitting CU blanks, filling CU holes with...
