If I was to install a new shower for someone using an rcbo as theres no rcd protection would this be ok? What i mean is am I ok as long as the circuit I have installed is protected? Or would it be up to me to make sure there was protection for the other circuits?
You need to notify this job so unless you are part p regesterd or going through building control you can not carry out this work
Paul
You are only responsible for the work that you do so fitting a RCBO will do the job nicely.
Chris
Personally I think that if the supplementary bonding was not up to standard then you would have to ensure that every circuit in the location is RCD protected and that supplementary bonding could be omitted in all the circumstances.
Part P is just England ain't it? In Scotland for some work we have to get a building warrant but not for putting in a new shower.
United Kingdom
No RCD protection...
SSE,
SSE,
