O
Octopus
Pretty much as the title says - lots of us have opinions but seeing as BEAMA seem to have ruled out plastic CU's lets have a poll - so please add your vote:
Discuss Plastic versas Metal CU's - your chance to vote in the UK Electrical Forum area at ElectriciansForums.net
It would,
I’ve been doing some digging around about phenolic plastics and the 960°C hot wire tests.
Like E54 I’ve tried to burn the Wylex wooden frame. Plain and simply it just doesn’t burn.
I'm still awaiting a response from Keith Smith at BEAMA to the following email I sent him:
"Keith
I appreciate your candid response and openness.
The quality of fuseboards has progressively dropped over the last 20 years and now they are so flimsy, and I'm not just referring to the, completely flimsy cases, it's the quality of the main switches, the mounting bars, the MCB's the RCBO's - this is what needs fixing.
Introduce a requirement for main switches to have 2 screws per terminal would be a step in the right direction and that coupled with improving the "strength" of the busbar for the MCB's and RCBO's would be good too.
My point remains that you can improve the case BUT ignoring the internal components and in some cases dangerous workmanship is not dealing with the problem."
Wilts appear to have a range of amendment 3 cus in stock now,Crabtree,Wylex & Schneider.
Surprise, surprise.....they're all over the place. A fair bit of hand rubbing going on, I'll wager.
and THIS is his response:
"HI xxxxx,
Picking up on your point - the drafting committee is made up of a wide range of 'interested parties' and 'industry experts'. The outcome is the consensus of their deliberations PLUS the public consultation (they call this stage a DPC = Draft for Public Comment) that was put out in December 2013 and closed in March 2014.
I can also confirm that the primary 'root cause' that was the catalyst for this particular regulation was agreed by all parties to be loose connections.
We will (as manufacturers) continue to consider any improvements that further enhance fire safety in addressing the root cause.
You make a reference to 'muppits' and in this respect we also find ourselves as Piggy (Miss) in the middle.
Best regards
Keith"
All I can add is Rxllxcks.
Loose connections - yup BUT the quality of the crxp materials doesn't help!
One has to now ask the now very prudent question of, are the DNO's going to be made to use Metalclad Service Heads on all it's new installations?? Or doesn't all the plastic Service Heads count in this shambolic new regulation regarding fire-proof electrical enclosures?? General use service heads haven't been made of any form of metal since the second world war, and are currently actually deemed as dangerous in many cases...
You couldn't make this stuff up if you tried!!
What the F**k has that got to do with anything?? Exactly the same situation exists (according to BEAMA/IET) no matter who's scope it falls under!! Service heads are all fundamentally plastic, so are subject to the same risk of fire is it not??
That's what happens, when knee jerk solutions are applied to situations, instead of addressing the actual problem. It always invokes other/further problems to be addressed, and will continue to do so until the underlying problem is sorted...
It has everything to do with it. They do not follow cable CSA when wiring house supplies nor volt drop on street lighting so why would they start here.
Don't be bloody daft, if the plastic is deemed to be a fire risk in CU/DB's then it applies to any electrical protective device enclosure, it doesn't suddenly change it's properties according to whose scope it falls under... It just goes to show how shambolic this knee jerk solution actually is!!
Reply to Plastic versas Metal CU's - your chance to vote in the UK Electrical Forum area at ElectriciansForums.net
