P
preppar
Good afternoon gents and ladies.
So I am having an argument, I say if I do any work on nearly any circuit, namely lighting and power, commercial
I have to upgrade protective devices so the circuit would be up to regs and on this case have either RCBO or RCD,
I ask you kindly to help me and tell me am I right or am I not right in saying that ?
Many thanks for your answers.
Many thanks for your answers.[/QUOTE
There are a whole host of regs that I think you and your boss need to get on speaking terms with
Your a trainee so I can understand your not as yet familiar with the regs.
Answer no there is not nearly every circuit that requires RCD protection, but there are quite a few circuits/equipment that do
Do you have a reg book to hand? As Malcolm says, there are exceptions to the rule for using RCD's.
Do you have a specific installation in mind?
As spoon said just a quick 4 that do
Domestic sockets under 20amp
Cable buried in a wall less than 50mm unless certain conditions are met
Agricultural Installations for fire protection (not though 30mA but 300mA)
Telephone Kiosk, bus shelters etc
And also quite a few other special locations
Thank you for a prompt answer, i mean nearly all, and we are having an argument ring main, had a mcb protection, one otlet cracked, if it is to be replaced, do you add aditional protection or leave it as it is ?
That is if the new amendment requires RCD.
Do you have a reg book to hand mate?
Where are the lights situated?
Check out Section 715 or the regs.
To list all the situations where RCD protection would not be required would take too long.
All you really need to know, is that your work has to comply with the REGs, it doesn't matter if the existing wiring does or doesn't.
Replacement of accessories or light fittings would not require RCD protection be provided.
Lighting circuit 12V dichroic to be replaced with LED + drivers, at the moment only MCB - overcurent protected
Lighting circuits don't need RCD protection unless they have cables without earthed metal covering buried less than 50mm deep and are unsupervised or if they are in a special location
Please help, I can't explain to my boss ! RCD protection
preppar,
Hawk,
