Sphurrell
Can you supply to aerial booster from upstairs lighting in the loft
Your post is a bit of a mystery mate, can you rephrase pleaseCan you supply to aerial booster from upstairs lighting in the loft
I was being what you called me a few weeks ago, something along the line of a sarky so and so lolthink OP means can you supply a TV amp from upstairs lighting circuit as usually there's not any socket circuit cabling in an attic.my answer is that you can as long as it's a dedicated feed for an amp, caretaken to ensure that the circiut is not overloaded by plugging excessive loads in.
