P
Phil
requested by the apprentices favourite teacher "amber leaf"
Amber has asked if we can have a discussion and a poll for the results
regarding the pulling of the fuse to which i think we all know where we stand regarding the DNO etc and not being allowed to. i will include a poll at the top for your thoughts.
If we are looking at raising the safety levels relating to domestic premises this is an absolute must. A pre requisite should be the immediate installation of a isolator. Therefore the process should be notifiable, as it currently is.
Oh I just love spending monney on the dole, uhm I recon 250 quid training course but you also have to be inspected yearly also could we have special tags that we have also to buy off someone to put on fuse enclosure to prove that a competant person pulled the fuse .
We could pay about a fiver each tag?
I am pulling my hair out have spoken with dno told them the situation with my mates house and today alone was given 5 different numbers and still told ring british gas as they supply you and they would have installed new meter
Where's the option "Pull the fuse if you want, but put it back in without a signed cert, cause a bang, and pay the fine"........
I know some DNO's are "insisting" on REC2 isolator switches being fitted on new installs, IMO they should be too - BUT.....the problem is NEVER in ISOLATING the supply, ALWAYS in what happens when attempting to reconnect it....which, as far as I remember, why it was made an offence to pull the fuse in the first place.
I know guys who will pull the fuse anyway, and claim there was no seal, or it was already broken, and that they didn't touch it (so, obviously did a CU change live!!!!).....or that they only pulled it BECAUSE there was no seal.....
And I've seen some idiots who are lucky to be alive at all today given what they have tried to reconnect to the DNO incomer.....
And to be honest, I think it isn't before time we go down the Gas SAFE route of having cards (The JIB should be doing this already IMO) with little symbols on the back up to and including whether of not the holder is competent to remove and replace the DNO fuse.
Far from paying extra for it, I think it should be a MANDATORY part of the primary electrical quals, AND update quals. No pass on this, no pass at all.
i was thinking along the same lines for the add on to say the 2391 or the 2330 l3 prac exam. there is so much we already have at our fingertips in this industry regarding regulating electricians etc so why they need to make it more difficult than it should be i don`t know. i for one would be happy to go on an update course run by the dno or somewhere sponsored by them. surely when they have to train their guys up to be able to do this it would be cheaper to just get a competent electrician on their list instead. i would be happy to sign a waiver for them regarding the pulling of the fuse that the emphasis is on me for the safely doing it etc and that i would provide my own ppe. i also think they missed the opportunity of fitting isolaters when they went round replacing the old type meters but i gues that would not have gotten them the call out charge they currently ask for.
Sadly, I think money is as usual what it comes down to.....it isn't necessarily safety or competence driven, but at some level (normally up there ^) that it is looked at in terms of revenue stream, and if they cannot see where else to regain that stream, it won't happen. Tough, but true.
Like you, I'm happy to sign a waiver, or disclaimer, and attend even an annual course to prove my competence to refit the fuse.
And like you, it would have been an ideal opportunity when replacing analogue meters to new digital ones, to also fit a REC switch.....but indeed, the other way was preferred - do your install, terminate your tails in a REC switch, and we'll come along change the meter and tail out to your REC. Then you can come back, and finish your testing....WTF??? Who does testing in two separate visits.....and WHAT would be to stop the customer operating the REC and potentially hurting themselves because THEY then have the ability to energise an untested, or only partly tested install?
OK, you can do all your SAFE tests, and be reasonably sure that you haven't got shorts, or incorrect polarity (with good eyesight), but....you cannot necessarily tell none of your accessories are faulty with only safe test or know that an RCD is properly operational.
IMO, and told to the DNO in question, it was bloody stupid advice, and my guy would under NO CIRCUMSTANCES connect our tails to a REC prior to the DNO connecting their tails. Energising of the system would only ever be carried out under our direct supervision.
Sometimes, even with DNO's you gotta wonder.....
I voted the 2391 option, but then noticed you mention safe isolation. I'd never consider pulling a fuse as safe isolation, even if its the supply fuse.
No, it's fair to say it isn't - as many service fuses also leave live terminals exposed.
There are valid grounds I think for a re-designed service fuse/isolator which ensures the incoming live supply CANNOT be reached fuse in or out.
And there goes another pig with wings.......
Which I assume is why the DNO's maintain they will isolate so encompass safety and a path to upgrading requirements. I will always maintain, although I've never done, its safer to pull the fuse.
What I would recommend is the JIB card, numbered seals available in every wholesalers, show your card to buy some to prove you are of a certain standard of safety. Once the seal has been replaced e-mail, text or call the DNO with your JIB ref and seal ref and everyone is happy. Cost effective, safe and traceable back to the spark that did the work even if the work carried out was like for like and none notifiable under the part p, only JIB members can do it legally.
Whilst I would agree with you in principal Paul, I believe that the cowboys will still find a way around the law - by using fake JIB cards or something. And would you trust the average idiot who works behind the counter of a wholesalers to be able to recognise a fake card?
Good point Ken. How about proving yourself as a competent electrician to your local DNO and getting the seals directly from them? That way they can send you leaflets etc on their own safe procedures. That reminds me, buy some from flee bay for my own c/u change that I did a few months ago. It just fel off soon as I looked at it ;)
pulling the fuse
Australia
Phil,
amberleaf,
