Discuss Question on CAT6 cable in the UK Electrical Forum area at ElectriciansForums.net
pirate
Supporter
Here is a pic of a CAT6 cable. usual pairs, plastic wrap, foil wrap, draw-cord, plastic separator...and a bare copper wire, which may be cca, i'm not sure...but what is that bare wire used for?
Mostly network cable is UTP = unscreened twisted pair. This is screened, but to get any benefit from the screen it needs to be earthed, and that is what the drain wire is for.
If you don't believe me, just try connecting to the aluminium foil....
Thanks for all your thoughts, and it is clear that wire is a drain. I don't use this type normally, just the usual UTP. I thought the aluminium screen was just that, a screen, and hadn't thought about its functional connection.
Aha...like a TV coax cable, which IS an aerial!
Theoretically a length of coax would be an ideal transmission line and pass 100% of the signal from the aerial to the TV, with no loss or leakage. Obviously in reality there are losses and small impedance differences. Smith chart anyone?
Smith chart? Please elucidate, every day's a school day...
(Not at the moment, obviously...)
It's a circular graphing system used for impedance matching in RF systems. Did them on my HND but wouldn't know how to create one now!
Reply to Question on CAT6 cable in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
I dropped my multi-tool onto a 10/3 wire yesterday when removing some rotted flooring in a mobile home. I could see a bit of copper so I don't...
So this is 1st floor maisonnette with concrete floor, 16mm2 single insulated tails coming from dual cut out on ground floor, through steel...
This question has probably been asked several time but things change. The house I'm living in now was built in the 1960's and has a ring main...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
