J.C.E
Up coming job....
fb currently in downstairs hall in a little cupboard- along with the head and meter.
job is a rewire anyways- but customer wants new fb moved into garage- on other side of wall to where it is at the minute. (Directly on other side of wall- litterally just popping through wall)
Run is <3meters but i will obviously have to drill a hole through the wall for my 25mm tails and 16mm earth
was planning on having a switched isolator where the old fb is- then tails into garage to new fb.
but as tails go through wall- guessing they need additional protection- do this by a upfront 100ma rcd?
cheers guys
Passing through a wall is not something which requires additional protection by RCD. And even if it did, a 100mA RCD is not appropriate for providing additional protection - only fault protection.
just an isolator. no need for fused, although that is an option. maybe a wylex KMF with 80A fuse.
What's the point in moving if then if your having to have something there still??
Surely it's making it more costly and inconvenient??
Sent from my iPhone using Tapatalk
You could say then Ristard that the OPs idea is fubar (fb) lol only messin no harm meant
J.C.E
Earth
Rcd for tails?
J.C.E,
7029 dave,
