M
Modernelectric
I have fitted a dual rcd board, and everything has tested fine. my only problem is that the rcd's do not trip on the 180 phase roatation, but trip within limits on the 0 phase rotation. I have swapped both rcds for new to check that the rcd's werent faulty and i still have the same problem.
Has anyone had any problems like this? any clues because this one is ****ing me off.
thanks!
May sound daft bit would your tester be fautly?
Have you since used it on any other installs?
Yes ive used it on other installs and its fine, its only a few months old, it seems no one else has encountered this problem then?! its a mystery to me.
RCD problems
Modernelectric,
Badged01,
