R
Rodgers86
Hello,
I’ve got a campervan with a 75ah lead acid leisure battery. Wired via a split charge relay.
Now I’m tempted to get rid of that and just use a jackery or Bluetti for my power needs.
However when I remove the leisure battery, could the existing wiring be used to power a cigarette lighter socket?
This would be ideal as the lighter socket could be used to charge my portable battery, and as it’s off a split charge relay, I assume this would then only be on when the engine is running?
