- Reaction score
- 5,180
Been to quote for some work today and the house is a new build.
Built by Linden Homes. At first glance looks good but when you stop and look a little closer you see several of the walls inside are not straight that there are big curves and deviations in them. when you look down on the accessories, there is gaps big enough to slide a 50p down behind in the middle due to the curvature... put a spirit level on wall to check for a tv bracket and on one wall i can put my little finger behind the level at one end as the wall is so warped.
They installed aerial points in lounge and master bedroom but told them cable is in attic, for you to connect an aerial... Linden dont supply one, but the best bit is that due to being in a low enclosed area surrounded by excavated mounds and other buildings, the signal is so poor everybody is putting up sky dishes but some houses cant get a line of sight, so no sky either!
Linden dont lay the back gardens anymore it seems, left them a pile of slabs and said for you to decide how you want it.
the most damming from my view is an outside tap, which is directly outside behind sockets, thought to myself a bit iffy... took socket off wall and behind the plastic back box in the plasterboard wall I can see the joint and pipe, so in the event of a leak or dodgy joint the water will be spraying into the back of the socket!
proves my point, never buy a new build house....
whats the worst thing you have seen on a new build?
