Discuss TT system inspection pit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Is there anything stopping you using a galv adaptable metal box labeled up?
I don't know of any specific reg however the clamp must be protected from damage both physical and from corrosion etc and remain accessible for future testing etc,
I used to use the silly little round boxes, designed by an utter ****, what utter utter ****s they were; However after one gruelling incident when I snapped the crimp eye for the second time, to stop me going on the rampage it was necessary repeatedly bang my head against a wall until i lost consciousness.
Therfore I now prefer to use the pits that are available from screwfix. There is so much room inside, you can stash a balaclava, neoprene gloves and a fair length of rope along with a selection of knives and further more you don't waist 200mm of rod above ground. A right blessing I say.
Yes!! ...Corrosion sort of springs to mind!! lol!!
They were not dug into ground but fixed to the concrete, steel conduit dropped down to box . The do as you likeys had been down a whole road and taken every cable from there rods. We did suggest pits but the housing association point blank refused the installation of the pits.
Hole through high level out of external wall, into terminal box down wall to ground level, right angle bend on conduit connected to adaptable box with brass bush and coupular.
There objection was they did not want the disruption of gunning up concrete the rods go through to install the pits, this translates to this way was cheaper for them.
Reply to TT system inspection pit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
