Are you sure its a spur from a ring, and not a radial circuit direct from board? (likely 32A breaker if ring, 16A if radial)
If it is a spur from a ring, can it be modified to become a fused spur? (unswitched fuse plate next to socket on ring before the branch)
As this thread, and the other similar thread linked above, the letter of the law in the regs book says no spur from a spur, and it mentions "points" whether that be a socket, or in your case a fused connection.
Safe, but not technically compliant.
Mm never thought it might be a radial and not at home just now to review but will have a look. Thanks for the advice. Appreciated
Turns out this was a spur from another socket. Decided to call in a pro. He is dropping in a dedicated circuit from a spare on the consumer unit. Thanks for the swift replies.
Manchester
United Kingdom
Wall lights 5 amp fused spur
DIY Electrical Advice
Hotdog6660,
Hotdog6660,
