Just removed some tired and grotty looking spotlights which were fitted to the top beam of my conservatory. Bro in law removed them first before I could look at how they were wired in but thought nothing of it cos its simple right? ?
Have bought 4 hanging vintage style pendants to replace them with. Anyway, only two out the four work, despite me and BiL getting up and wiring them and checking them a dozen times. #1 works; #2 no; #3 works; #4 no
So where are we going wrong?
This one is the second of 4 from the wall and has two times NEL from the loop (as do #1 and #3)
This is #4 at the end and only has one NEL wire
Welcome to the forum mate.
Are you saying that the above is the way its wired or just the way you have numbered them?
Does 2 wire back to 1, 3 wire back to 2 & 4 wire back to 3?
Can't see how 1 & 3 would work and 2 & 4 not unless the wiring order is 1, 3, 2 & 4 and there is a bad connection or cable break between fittings 3 & 2
That's why I wanted the wiring confirming. Gives us more of a clue to what is happening.
As the wiring is inside the apex of the conservatory the problem is I have no idea which order and which ones are connected to others etc.
I'm first of all going to recheck ALL the terminals as so far I have been assuming that #1 and #3 which work are fine and not rechecked those.
Bit rough chopping the connector blocks off the centre to get the wires to reach and not using earth sleeving . But anyway, I assume you swapped the lamps [bulbs] round to confirm you didn't have two duds before taking everything apart again ? And also make sure the bulbs are firmly screwed in.
Yes I chopped the terminal box up and then experimented with Wago connectors to help with assurance of termination, and also ease of connection as I'm 12+ ft in the air on a ladder and not that comfortable at height so wanted a quick secure connection and then get down.
Yes. But would appreciate a step by step as a beginner to help test and fault find.
A 2-wire voltage tester and check for 230v at fittings that don't work
Check bulbs fitted tight and working
You can then use a voltstick and check on the L-E if possible without tripping RCDs to see what's present if anything
Continuity on L-E is another one if you're trained and only in the right circumstances
So you can possibly establish 230v present , L present and even N present just by testing
But those would require a little experience and can't always be done safely , but it's what's possible to check in the right situation
Midlands
United Kingdom
Where am I going wrong with conservatory lights?
Lighting Forum
MagnumPI,
telectrix,
