Because you haven't set it to No Trip, or you're repeatedly testing the RCD?
any one tell me why a new meter would trip rcd repeatedly .
Is this meter a Test Instrument? If so then read the user instructions. My Fluke voltage indicator tripped RCD's for fun till i read the instructions, and now it never trips them.
Cheers.........Howard
If it's the supply meter, it's most likely a loose termination, probably the neutral.
I'm not the only one who was surprised that it tripped everything. It took me around 3 weeks before I realised it shouldnt work like that!
Aaln.
If its your supply meter you really need to contact you supplier as if its a loose connection its only a matter of time before it heats up it needs sorting ASAP.
Get them back before you start cutting seals etc(as it would of been resealed on replacment) or they will point the finger at you for tampering
why is new meter tripping rcd
Talk Electrician Forum
castor,
tony mc,
