Currently reading:
Strain relief for spade terminals
Discuss Strain relief for spade terminals in the Auto Electrician Forum area at ElectriciansForums.net
J
Jodes
I'm worried about putting spade crimp terminals onto a cable for use in a vehicle.
I'm worried about the conductor strands at the connector flexing and breaking over time.
There seem to be terminals with one, and with two crimping clamps - so one will be for the conductor alone, and the other for the insulation+conductor.
Would it be acceptable to use ones with a single crimp section?
For example, using 16A thin-wall multi-strand single cable, to connect with an insulated terminal onto a pole of a lighter socket.
I was considering using heat-shrink sleeving on top of the insulated terminal, extending to part of the wire, to provide strain relief. Is this necessary? Is this enough?
Thanks again
If you're using non-insulated crimps, make sure you have the correct crimper and good quality crimps.
I wouldn't worry about strain relief, unless what ever you are crimping to is going to be moved around a lot.
Insulated crimps of that nature just compress against the conductor, where as if you have non insulated crimps, the twin type, the crimper tool bends the little flames over etc.
I was really more thinking about vibrations in the vehicle - besides the vibrations, there wouldn't really be any movement.
Ah ok, I get it - I didn't realise uninsulated crimps are always the twin type - thanks!
The picture Marvo has posted shows a crimp which is intended to be used in a multi-plug.
The inner core of the wire is gripped, and the insulation is gripped whilst also being pierced by the ends of the tangs.
A cheap crimper might form a crimp where the insulation is gripped and pierced, but the inner core loose. Alternatively, it might form a crimp where the inner core is gripped, but the insulation is loose.
It some cases the insulation is not pierced, in others it is pierced to such an extent, that the wire is likely to snap.
Cheap crimps, generally use less material, so often the tangs are too short to pierce the insulation, and sometimes the material is not thick enough to grip either the inner core or the insulation.
It's just a few to start with, but I may end up doing more work on them and I'd like to get into the habit of doing a good job, I've got a basic crimping tool but I don't think it would make the crimp tags fold like they should. (Picture below). What kind of crimp tool would do the best job?
I have a friend that is a Avionics engineer, he was telling me crimps were the only thing they use when they terminate electrical wires.
Was saying that screws /bolts are never used because vibration would ultimately cause them to fail .
Although his crimping tools are serious quality , and have to be calibrated quite regularly.
Since then have happily used them, just like other people have advised , don't get cheap ones or fittings - but if they are good enough for the aircraft industry , a car will be fine :smilewinkgrin:
I suppose the only remaining question is how can I tell if crimp terminals are good quality? I haven't seen any local avionics stores! Sort of surprising given I'm near Biggin Hill lol. I would go for branded items, but I've learnt not to trust brands as far as I can throw them.
I've not got these ones but I would highly recommend Knipex, they will be about £110. I've got a few of the other type of crimps and they are if exceptional quality.
£110 for a set of crimpers? they better come with a calibration cert for that kind of money.
i would recommend tri-rated bs6231 cable or yy, its a lot more flexible than say 6491b so it wont snap, 6491b has very fine strands so will be fine
Jodes have found these type of crimps - this will be fine around £25-30 , I have had mine for years .
Insulated Terminal Crimping Tool - Standard Duty | 12 Volt Planet
Not that you will need all of these but this type of crimps.
385 Piece Pre-Insulated Terminal Kit | 12 Volt Planet.
depending on how many wires are going in , the red should be fine for 12v.
The jaws on crimper are colour coded so you cannot go wrong- I find it easier to put crimp in jaws first,
Crimp down so it just grabs it , then inserted stripped wire with other hand and just crimp down- it will not open up until you have right pressure - so cannot get it wrong mate- just practice on a couple first.
there just standard crimpers, go for a proper branded pair for that price.
just be careful that some crimpers jaws put more pressure on one side than the other
Reply to Strain relief for spade terminals in the Auto Electrician Forum area at ElectriciansForums.net
