Currently reading:
Metal Consumer unit with SWA bottom entry
Discuss Metal Consumer unit with SWA bottom entry in the UK Electrical Forum area at ElectriciansForums.net
Got a job to replace an old metal Wylex CU (domestic). SWA is embedded in the wall except the last 300mm (or so) and then comes out and enters CU via a gland.
Obviously looking at a metal replacement and have been looking at the new Hager options but these don't look like they'll take a bottom entry SWA very easily. Busbar seems very close to bottom of CU. Swa is 25mm, so not that easily bend to avoid, and there isn't the usual space next to the incomer switch as found on the plastic versions.
Any suggestions?
the schneider isobar type A have a lot of space in the bottom
Reply to Metal Consumer unit with SWA bottom entry in the UK Electrical Forum area at ElectriciansForums.net
