Currently reading:
How to get network cable up/down cavity?
Discuss How to get network cable up/down cavity? in the UK Electrical Forum area at ElectriciansForums.net
I realise putting mains cables in a cavity is a no no but I need to get a cat5/6 cable from downstairs to upstairs in a dorma bungalow and thought the cavity might be a good route?
So does anyone have any tips to get a network cable through a cavity?
Cheers for any help.
Forgot to say the cavity has no insulation.
^^ transfer rates are affected by RCD's, so if the 2 adaptors are on the same circuit then they should be OK.
As for expensive - not sure I agree
Why not use outdoor grade CAT5 and run it up the outside?
Drill a hole on an upward slant, push up some rods and then in the loft space attach Cat 6 external grade and pull downwards. I have had had varying degrees of success and snapped a few pull rods in the past, but always worth a bash.
The trick the cavity wall lads use when brushing off a cavity to next door is to drill a hole at the top, drill a hole at the bottom perfectly in line then feed a chain in through the top hole and fish it out the bottom hole with a wire coat hanger with a small hook formed into it....Naturaly the chain drops in a straight line due to the weight. Not that I'm advocating you use the cavity but sometimes needs must. ;)
I have powerline adapters in my house. Had no problem with them and think they are great for what I need.
Not wanting to state the obvious.... Just make sure the house doesn't have 'cavity wall insulation'. Will defo change the way you do things.
Interesting but there is nothing to stop anyone using these, and sometimes they are necessary.
Sorry i don't agree they are necessary. There is always a way be it a bit awkward. As I said what would you so if they did not exist?
Ofcom have in fact dealt with several hundred complaints of interference in particular with Comtrend types supplied by BT who were asked to remove them.
Everyone to their own opinions. I like the Powerline Adapters.
If they did not exist then I wouldn't like them...
I would either scrap the idea of extending the coms or have to have the cable fitted.
Used to use the mouse all the time when cables were run in cavities a few years ago. Bit of string with a small chain in it, drill a hole at the top, drop it in and fish it out another hole below. Used to be quite exciting hearing it dropping down inside the wall and fishing it out.
exciting till it gets half way down the first wall and hits mr dwang, i like working in older homes where it does just go right from the loft all the way to the bottom floor
Reply to How to get network cable up/down cavity? in the UK Electrical Forum area at ElectriciansForums.net
